Budget system
how does this sound for a 1 ft^3 enclosure
24"w x 12"h x 6"d
i believe the mounting depth is 5 5/8"
will the back of the sub be to close to the back of the box or does it matter?
Try at least 7" mounting depth, so the pole vent has adequate ventilation
p.s. I would strongly urge you make a ported box. My 2000SPL's did not like sealed.
Nice setup for 120 bucks by the way. Don't forget you need to spend money on wiring and the box, though.
it has to fit in a reg cab truck so ported is out of the question
7 may be a lil deep hold on ill go check......
7 is do able proly
could i bring the hight down to 11 or is that to short for a 10" sub
it has to fit in a reg cab truck so ported is out of the question7 may be a lil deep hold on ill go check......
7 is do able proly
Do 6.5" depth to save a little space, 11" wide/tall would be fine.
I would basically find my dimensions and make the biggest box possible if its going to be sealed //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
tmilla
MMMMMMM Cheese
tmilla
Wisconsin
tmilla
