OP
2013Sonata
J Rizz
- Thread Starter
- #16
I tried trimming but wasn't successful at all. I trimmed off a bunch of strands too. I just have no luck lolhmmm you should be able to just trim the wire down an twist an fit them in. im running Shok 8g for my speaker wires an it worked just fine.
**** those plugs are nuts. Where'd you get them? lol. I have some rinky dink plugs. As far as my torch, it's a Bernzomatic mini torch. It works soooo much better than my wireless soldering iron. I wasn't able to do a thing with it. lol.get some heavy duty banana plugs..
got 4 gauge into these ones easily lol
or several of the above suggested ideas would work. Try using a little bit of soldering Flux next time you try and solder bigish wire like that 12 gauge knu. Use a high quality iron, or small torch for best results. Trimming the wire and twisting like you've tried to do is another easily done options as well.
good luck
