Doing Big 3 today
I didn't replace any wire...I added. I wish I seen this earlier. For engine to chassis I ended up bolting the wire down to the power steering pump to frame. Where is the alt case bolt?
I currently have optima yellow top under the hood and my gain is set right in the middle ...lp filter is at 80hz, subsonic filter is at 25hz, and the bass eq setting is at 0. I sanded down my ground until the metal was shiny.
Gain could still be too high... set it with an Oscilloscope/DMM if you have one available. And make sure the ground is in a good spot that is connected to the chassis
I will change that ground from the water pump to chassis tomorrow to the alt case bolt like you mentioned to me and see of that helps out but as of now it seems as the big 3 didnt help anything. I will takeb pictures of everything when I get off of work in the morning so you can get a visual of what I did and hopefully correct any of my mistakes I may have made.
Sometimes doing.the big 3 hurts if u dont have thes rest set right bc u have alot more power flowing now amd ur amp can draw more
dboii313
dboii313
Romulus, MI
NASTY08IMPALA
