Bridging 4 channel amp......
mannyahles
I just want to make sure that I am bridging correctly......
I am installing one set of Hertz MLK comps passively. So I will do the following:
Channels 1+ and 2- bridged and 3+ and 4- bridged but how do I hook up channels 1/2 to one passive crossover and channels 3/4 to the other crossover?
The croossovers have a place to plug in for the tweets and mids.....????
as for your passive xover, most that have the bi-amp capabilities has the option to be bi-amped or not.
I'd suggest use that 4 channel and NOT bridge it and bi-amp your comp set.
That'll mean each mid and tweet will have it's own channel of amplification.
Typically, when bridging a 4-channel amp to two 4 Ohm mono outputs the method followed is such:
Positive (+) output from Channel 1 is combined with the Negative (-) output on Channel 2. You're left with a single, more powerful output with positive (+) and negative (-) leads, one of each. Let's further assume for the sake of argument you've connected Channels 1&2 on your amp to the left output(s) from your headunit.
The same procedure is followed using the positive (+) from Channel 3 along with the negative from Channel 4 fed signal from the right output(s) on your HU.
If your amp has a manual switch (some older ones do) for running mono bridged then you'll want to engage that now.
You now have two 4 Ohm outputs, one left and one right.
Attach the left output you made by combining Channels 1&2 to the left crossover inputs.
Do likewise for the right amp output and the right-hand crossover inputs.
Voila! Done!
Voila! Done!
I understand bridging but I will have only 1 set of wires (+/-) going to each crossover. ON the crossover there is a spot for tweeter and midbass so how do I connect them. Or do I plug in where the bi amp is on the crossover?
The Hertz MLK's are power hungry so I have been told to bridge my amp so the comps can get more power....which they love!
My Orion is 100 x 4 or 200 x 2 bridged!
It's good enough...
Where it's says "bi-wiring" instead of "bi" set it to "mono" if you want to bridge your 4 channel.
I'd rather bi-amp, but that's just me.. actually I'd bi-amp AND get another 4 channel and bridge that sucker to your mids.
mannyahles
mannyahles
Carlsbad, Ca
mannyahles
michigan born
    May 14, 2026
michigan born
    May 14, 2026
