Bridged vs 2 channel?
It depends on the coil configuration of your subs. What subs do you have? If you don't know what the coil configuration is, check the sub or list the exact model and we'll tell you how you can wire them.
Sent from my SCH-I545 using Tapatalk
It's a Rockford Fosgate Punch 801s. It's not manufactured anymore. I have 2 different sets of 12" subs. My Alpine Type-E's are single coil. The ones I have in the car are Pioneer's. I can't figure out what type they are without actually opening the box up which will be a pain. I can do it later if I must.
Pioneer TS-W301R 12" 4-ohm subwoofer at Crutchfield.com
That's EXACTLY what the subs look like. If that helps.
I am VERY new to all this. I was able to set up the wiring without issue. Started off with a cheap Dual Sub and Amp. Just trying to learn a little more. I am assuming because the subs peak power is 800w that bridging them would offer more peak power over the 2-channel pushing out 200w x2 @ 4-ohm. I am also assuming you can't change the ohm's?
---------- Post added at 08:03 AM ---------- Previous post was at 08:03 AM ----------
Probably will fry those pioneers bridged at two ohms. Not real beefy
The guy who has them before me had this setup in his truck for two years. I figured it they lasted 2 years they were okay to go in my vehicle.
---------- Post added at 08:04 AM ---------- Previous post was at 08:03 AM ----------
How does that work anyway? If they are 4-ohm subs, why would bridging them be 2-ohm?
ZeromusX
ZeromusX
Spring Hill, FL
ZeromusX
