BP1200.1work with 2 subs?
You could wire a billion subs to one amp as long as the impedance doesn't go lower than the amp could handle. You said you have two DVC subs and I'm guessing that each coil has 40hm resistance. With that you could run both subs with Impedance of 1ohm or 4ohms with the mono block. you'll get 1ohm if you run the wiring parrallel-parrallel. you'll get a 4ohm load if you run the subs in parrallel-series.
yeah you can use that map easily with those two speakers make sure you make it a 1ohm load bc if you make it four ohms you will only be getting 600 watts total but at 1ohm you will be getting over 1200 total
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
988
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
697
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
570
RavE
RavE
Oregon
silentscope21
