box tuning question
Etac
Angry Bunny Killer
ok i know there might be too many variables to answer this question but if possible...
assuming you have a sub with a perfectly flat response from like 20-80hz...
and your box is tuned to 32 hz.. how much does the box influence that specific frequency...?
What do you mean it has a perfectly flat response from 20-80hz? Are you referring to the spec on the speaker that says Frequency Response: 20-80hz or whatever? If so, that does NOT mean the sub will play perfectly flat from 20-80hz as that is very enclosure dependent.
If you have a sub in an enclosure tuned to 32hz, there is a VERY slight chance you will have a flat response from 20-80hz.
depends but box size can play a big part
heres the 12w6v2 in 1 cube tuned to 32 and 10 cubes tuned to 32
red is one cube
yellow is 10 cubes
Etac
Angry Bunny Killer
Etac
Jersey
nauc
