box size question
  • 5
Colossus281
I think im going to be running two 15 inch ssa icons. Now the questions from what I have read its best at 3-3.5 ft per sub and then optional 4 ft per sub. What would be the best for me I plan on running them on 2k rms and 3k for competition and showing off
I'd definitely go with this if you're planning on pushing a bit over rms. If you make it the 4cf, being that the sub is made for 2000rms, when you go over rms you may push its excursion limits. Keeping under that volume would lessen excursion and increase the amount of power you can push through it imo.
The icon is 1250w.
3.5-4 works very well. You can alter the port area and tuning to work better with different power and your application.
The icon does not require a ton of power to perform very well.
Yeah I'm just waiting for the new 1500rms skar subs to come out so I know they're spec sheets and how much thay are going to be before I make a decision on subs
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Colossus281
Colossus281
Albuquerque nm
wenn_du_weinst
