box size question
I'd definitely go with this if you're planning on pushing a bit over rms. If you make it the 4cf, being that the sub is made for 2000rms, when you go over rms you may push its excursion limits. Keeping under that volume would lessen excursion and increase the amount of power you can push through it imo.
The icon is 1250w.
3.5-4 works very well. You can alter the port area and tuning to work better with different power and your application.
The icon does not require a ton of power to perform very well.
Colossus281
Colossus281
Albuquerque nm
wenn_du_weinst
