box placement/ securing
Even if you were to drill into the sheet metal wouldnt you want to use a bolt and not a screw? Excessive vibrations can cause the screw to back out as well as inertial forces pulling on the box in heavy cornering might cause the screw to pull out of the hole and strip out.
good point but my two 12'' L7's banged pretty hard, and i drive like a maniac ...never loosened my screws on my L brackets
ok i just really dont wanna go too far and knick a wire or puncture something ya know?.... and use L brackets to right?
just make sure you check beneath where you are drilling. lift up the trunk carpeting to see if anything is beneath it and the sheet metal. then check below the sheet metal of where u are drillling...its the same concept of drilling a ground into ure chassis
ya theres nothing under the carpet cept the sheet metal i think where i wanna drill inside gotta go crawl under there and check under the car tomorrow i guess to see wats under the sheet metal
i think where i wanna drill is right above the axel.... i wanna drill between where the sparetire is and the gas tank which would be like right above the axel... i have a 2000 altima gxe... think ill b fine?
yeah man as long as you pay attention to where ure drillling you will be perfectly fine. just dont use cheap screws!
jbsilentkill
jbsilentkill
Apopka,FL
jbsilentkill
