Box material and thickness compromises.
  • 4
nrgy
USA
I know MDF is the most recommended material for box construction, however I can only buy them in large sheets, and I simply don't want that much. Could I just use some Birch or Oak panels to build the box from? These are fairly dense woods, and I don't understand why they wouldn't work just as well.
Also, would anyone advise against using 1/2" wood as opposed to 3/4" for box construction, using an 8" sub with 150w going to it?
Originally posted by nrgy I know MDF is the most recommended material for box construction, however I can only buy them in large sheets, and I simply don't want that much. Could I just use some Birch or Oak panels to build the box from? These are fairly dense woods, and I don't understand why they wouldn't work just as well.
if ur only using a 8" sub u would be fine w/ 1/2" and i would use oak
a sheet of mdf is cheaper than the exact amoun you need of oak -- look around at the store, mdf is commonly used for shelves as well and comes on 2-4 * 4 foot sheets at most places (ie home depot, lowes ect...)
Originally posted by evo2k3 a sheet of mdf is cheaper than the exact amoun you need of oak -- look around at the store, mdf is commonly used for shelves as well and comes on 2-4 * 4 foot sheets at most places (ie home depot, lowes ect...)
This is what I would do.
But for an 8" with only 150w RMS, the Birch or Oak paneling would work also.
- Steve
I am sure there are hard woods that are much denser than MDF. Don’t know if they would be better for a build, but they would certainly be...
24
729
755
nrgy
nrgy
USA
ss3079
