Box material and thickness compromises.
  • 4
nrgy
USA
I know MDF is the most recommended material for box construction, however I can only buy them in large sheets, and I simply don't want that much. Could I just use some Birch or Oak panels to build the box from? These are fairly dense woods, and I don't understand why they wouldn't work just as well.
Also, would anyone advise against using 1/2" wood as opposed to 3/4" for box construction, using an 8" sub with 150w going to it?
Originally posted by nrgy I know MDF is the most recommended material for box construction, however I can only buy them in large sheets, and I simply don't want that much. Could I just use some Birch or Oak panels to build the box from? These are fairly dense woods, and I don't understand why they wouldn't work just as well.
if ur only using a 8" sub u would be fine w/ 1/2" and i would use oak
a sheet of mdf is cheaper than the exact amoun you need of oak -- look around at the store, mdf is commonly used for shelves as well and comes on 2-4 * 4 foot sheets at most places (ie home depot, lowes ect...)
Originally posted by evo2k3 a sheet of mdf is cheaper than the exact amoun you need of oak -- look around at the store, mdf is commonly used for shelves as well and comes on 2-4 * 4 foot sheets at most places (ie home depot, lowes ect...)
This is what I would do.
But for an 8" with only 150w RMS, the Birch or Oak paneling would work also.
- Steve
I am sure there are hard woods that are much denser than MDF. Don’t know if they would be better for a build, but they would certainly be...
24
3K
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
192
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
539
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
841
nrgy
nrgy
USA
ss3079
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
