box help
hey guys, im not on here much do to work and school, but i really need help.
I recently gpt build a box for my 2 DD 1508's it is a box that has 1 cube foot per chamber with a baffle board in the center. i put 2 3 inch aero made out of pvc pipe in the box, i am running it on a Memphis PR 500.1 at 1 ohm. i tested it out the other day and only got 123 DB. i know this is not right and it really baffles me and pisses me off how everybody says the box should work but it dosnt. BTW, the box is subs up, port back. if anyone could please help me i would appreciate it thanks
I have never heard of a ported enclosure that measures only 1 cube. IIRC, ported enclosures are generally larger. But if your set-up is correct then the only thing I could suggest is adjusting the length of your ports until you find the desired frequency/DB.
Black94Stealth
Black94Stealth
Statesville, NC
Black94Stealth
vegang
vegang
