Box help!
  • 2
bowtiefan
East TN
I've spent countless hours designing this box for a 15" K that will fit my application the way I need it to.It has about 3.7^ft of airspace after driver and port displacement.My problem is the port.I was going to use an Aero-Port but I dont have the room to do it on the box,so my next idea was the slot port which is what you see here(the red line).My question is will this be alright?I know the port is suppose to be on the same panel as the sub,but that is not an option here.Any ideas/advice will be greatly appreciated......thanks
cool......I hope anyway.......gonna build the box one day after x-mas.......then I'll just be waitin on the K.......
thanks vette.......but my problem is I dont have enough box area to mount that 7.25" flare and I was gonna have to use 2 of them to get my tuning right
oh, i must not have understood. i was about half asleep then.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif anywayz, just go with the slot port and u will be fine.
Originally posted by vettelovr1124 i was about half asleep then.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Happens to the best of us....//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
990
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
697
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
bowtiefan
bowtiefan
East TN
bowtiefan
    May 12, 2024
Brendon Jenness
    May 11, 2024
