Fitting custom stuff, angles, chambers, etc..
  • 1
Savant
Duke of DOH!
Hey all..
I have tried (although with a bit of lamness) to draw out the situation I was thinking about..
I have a 2001 ZR2 (s10) Blazer.. I was thiking about how I could get my 2 12"s and and 2 10"s in the bed/back and not have 'boxes' floating around.. I also took the spare tire (31.5" off road tires) off the back of the truck and have it in the bed.. it looks stupid on the back of the truck *sigh*.. So, now.. I have most of the floor space filled with the tire if the back seats are up (I keep them down as a rule but would like to be able to lift them if needed).. so, I was thinking I would build a platform around the tire (hiding it for the most part, still would have a 'floor' above despite it being 12" - 14" above the 'old' floor) so I could leave it in the truck. I was thinking about a sliding table in that space for the amp rack too (since it's not a good idea to attach amps to boxes?)..
The first picture is of the top-down look at the bed of the truck.. The second is a look from the back looking in.. 3rd is top down 'with speakers', 4th is from back looking in..
The thing is, I don't think I'll be able to have 'cube' shapes for the chambers if I want to maximize space.. So, part of the question for this post it.. does it matter if I have several 'off shoots' on the main chamber to get a total volume needed (pic 5 kinda shows what I'm asking)? Does the port have to be in a specific spot (based on the plane of the speaker) to avoid problems or can it be 'like the pic'..? If I have to keep basically 'open' space for the speakers, I think I'd have to build over the back seats and would have a lot of wasted space..
K, thanks for the info //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
985
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
696
That might depend on the head unit. Some can use a 5 amp fuse, some a 10amp, some a 15amp fuse (if / depending on how much it's powering the...
5
Lmao it definitely could have. Im in construction so i have some aptitude of building and fixing ****. If i was just a regular joe i would have...
6
Savant
Duke of DOH!
Savant
Colorado Springs, CO
Savant
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
