Box help for 18" Nightshade
Slammer
NC
I have an 18" Nightshade on the way, and will be putting it in my GMC truck. I checked at Sundown, and Jacob recommends 4.0-5.0 cf vented. I want to get loud with this (running at 1ohm on SAZ1500), but still want some SQ without the box getting too big. Here is what I am thinking.......
20"wide, 18" tall, and 34" long
That gives me a gross volume of 5.74cf. The woofer displacement is .26, leaving me with a net of 5.48cf before port volume and bracing.
The sub must be upfiring, as it will be on a platform in the rear compartment of an extended cab truck. With this being the case, I am considering a slot port in one of the sides. I want to get to about 35hz with my tuning, but have yet to get on a port calculator. I am guessing that I will use 1.2-1.5cf for the port, with dimensions of 5"x16.5"x20" long (approximate).
I have run 15s for quite a while and have built several boxes for them ranging from 3.25 to 4.50cf net. First time with an 18, and would appreciate any insight. I know that the sound characteristics are quite diferent, and don't want to make a critical mistake in my box design.
Thanks!
Yeh, 4.0 would be ideal, but I don't want to give up too much SQ, in my attempt to save space. You got good SQ with 4.0 @ 32?
I am in Raleigh, but can do the box myself (once I get the sub and decide on a plan). Thanks for the offer though! I am gonna play around with a few calculators, aiming between 4.5 and 5.0cf and right around 35hz. Thanks for the input.
Slammer
Slammer
NC
Slammer
