box for 10" Mach 5
Actually looks pretty darn good but it is a bit large for a 10" (volume of the enclosure)...
And if youre worried about port noise make sure to always round-over the mouth of the port and also the end of the port...it is also a good idea to put a 45 degree angle insert into the corner/turn of the port too..
there are no parameters or recommended box sizes on their website so i figured 2cu^ft would be good... im also not really sure what to tune it too either!?! i listen to rap...
what will happen if the box is "too big"? what will a different port tune do to the sound? like 30hz vs 32 vs 34?
if a box is too big: the dampening of the cone will be less and the sub can be more prone to bottoming out. it will also give a smoother sound, but power handling is decreased.
the opposite happens in a smaller box.
so i should go for 1.5cu^ft taking into account displacement tuned to 32hz? what would i hear differently if i tuned it to 30hz? 34hz?
download winisd and your'll see that a higher tuning will give you a peaky response curve. this is useful for spl but for music i wouldnt tune higher than 35 for daily, even thats pushing it imo.
I would go less than 1.5 cubes a bit...and tuned around 32Hz (you really cant go wrong tuning 31-33Hz IMO)
so u are saying do 1.3cu^ft before displacement? and with tuning, the lower it is (to about 30) then the more spl and the higher (lower than 35) the more sql?
around 1.3 net should be suffice i would think. if anything just email mach5 about it, they have great costumer service.
the lower the tuning the flatter the response curve will be. well usually depending on car acoustics and cabin gain ect. the higher you tune, it tends to be a bit peaky but a bit louder, again depending. its easily shown using graphs but my winisd is on my the other computer.
liljojo4711
liljojo4711
dallas
liljojo4711
michigan born
    May 14, 2026
michigan born
    May 14, 2026
