Box Design questions
The reason I think they can hit 32 Hz is because the site says it, I don't know that much about this that why I am here. I do like the FI-Q 15".
The thing I don't like is all the coloumns.
DUAL 1 | DUAL 2
Fs: 32.4 Hz | 32.1 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 8.52 | 8.61
Qes: .43 | .44
Qts: .41 | .42
Mms: 293g | 299g
Cms: 0.82mm/N | 0.82mm/N
Sd: 810cm^2 | 810cm^2
Vas: 75.6 l | 75.6 l
Spl: 89.6dB 1W/1m | 89.4dB 1W/1m
Bl: 13.9 N/A | 19.65 N/A
Xmax: 28mm
Rms: 1000W
Sealed box: 2-2.6 cuft
Ported box: 2.8-4 cuft @ 28-33Hz
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.500”
Displacement: 0.19cuft
I don't know any of that
32hz is simply the free-air resonance of the subwoofer. It is not a strict indicator of how low the sub can play, though it does play some part in the equation, since subs with a lower fs generally play lower tones easier(in the right box).
Again sorry for double post, my previous post was not shown yet. Does anyone know by chance what Ohm the FI-Q 15" is? would help to know so I can choose amps correctly.
SkyLegend
SkyLegend
chi-town
pro-rabbit
