box design help
so here is a suggestion, any changes let me know:**
E n c l o s u r e** S p e c i f i c a t i o n s :*F b** =** 3 6** H z*V b** =** 6** f t ^ 3*
E x t e r n a l** H e i g h t** =** 2 0** i n
*E x t e r n a l** W i d t h** =** 4 7** i n*
E x t e r n a l** D e p t h** =** 1 8** i n*
P o r t** W i d t h** =** 6** i n*
C u t** S h e e t** L i s t :**** A l l** D i m e n s i o n s** i n** I n c h e s .**** W o o d** T h i c k n e s s** i s**** 3 / 4** f o r** a l l** P a r t s .*
E x t e r n a l** E n c l o s u r e** P a r t s :*
2** x** F r o n t** &** B a c k** ( 3** p a r t s )** =** 4 7** x** 2 0*
L e f t** &** R i g h t** S i d e s** = **S i d e** 1** =** 1 8** 1 / 2** x** 1 5** 3 / 4*S i d e** 2** =** 1 9** 1 / 4** x** 1 5** 3 / 4*
T o p** =** 4 0** 1 / 4** x** 1 5** 3 / 4*
B o t t o m** =** 4 7** x** 1 5** 3 / 4*
L** P o r t** I n t e r n a l** A s s e m b l y** P a r t s :*T o p** t o** B o t t o m** =** 1 2** 1 / 2** x** 1 5** 3 / 4*
Ext e n s i o n** =** 1** 3 / 4** x** 1 5** 3 / 4**hows that sound i have a pic of howd it look
A ext cab truck
Nice //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif So basically you're looking to sub front / port front while staying below the window line then I take it right? And @ 36 hz with a 6" L-port (sorry that 1st post is sketchy to read lol) If what I just said is true, then I wouldn't run a full 6" wide x 18.5" = usable height for this size enclosure with front port... It will eat up way too much space away to get you down to 36 hz... I'd do a 5.5"W x 27.5"L x 18.5"H - That will net you around 5.5^ft after woofer displacement and bracing, double baffle, tuned @ 36hz with your above dimensions - If this is what you are in fact after...
Ok yea thats kinda how it is i endd up doing what you said with the 5.5" port when i get off work im goin to re post one with my new dims n you could tell me how that sounds its kinda the same but lil mods to it lol
*E n c l o s u r e** S p e c i f i c a t i o n s :*
F b** =** 3 6*H z*
E x t e r n a l** H e i g h t** =** 1 8 . 8 7 5** i n*
E x t e r n a l** D e p t h** =** 1 9** i n*
P o r t** W i d t h** =** 5** 3 / 8** i n*
C u t** S h e e t** L i s t :**** A l l** D i m e n s i o n s** i n** I n c h e s .**** W o o d** T h i c k n e s s** i s**** 3 / 4** f o r** a l l** P a r t s .*E x t e r n a l** E n c l o s u r e** P a r t s :*
2** x** T o p** &** B o t t o m** ( 3** p a r t s )** =** 4 7** x** 1 9*
Le f t** &** R i g h t** S i d e s** =** 1 7** 1 / 2** x** 1 6** 5 / 8*
Fro n t** &** B a c k** =** 4 7** x** 1 6** 5 / 8*
L** P o r t** I n t e r n a l** A s s e m b l y** P a r t s :*T o p** t o** B o t t o m** =** 1 1** 1 / 4** x** 1 7** 1 / 2*E x t e n s i o n** =** 3** 1 / 8** x** 1 7** 1 / 2
Yea see im new to building boxs so im not sure id prefer the lows but im going to running daily on about 1500-2000k to it and i askd same ? On smd and couple ppl told me to just build my own way lol not alot help im just trying to find best for daily and its only going to be single for a month or 2 then im going to with 2 or 3
urlocalpothead
painesville ohio
Buck
Mike Mccabe
