Box Design for JDBoogie
DNick454
Honda + Subs = Rattles :(
JDBoogie contacted me asking for a design for his two 10" IDq V3's and requested that it be around 1.5 cubes per sub tuned to 28Hz per manufacturer spec so I figured I'd post what I came up with incase anyone else would like to use the plans.
Here's the actual dimensions of the box. Took a bit of fiddling around to get a rather small box tuned down to 28Hz and still stay in his car parameters:rolleyes:
Construction:
Material - 3/4" MDF
Double Front Baffle (Flush Subwoofer Mount)
--External Dimensions--
Width: 40"
Height: 16"
Depth: 16"
Port Height: 14 1/2"
Port Width: 3 1/2"
Port Area: 50 3/4" squared
Volume (with port + braces subtracted): 3.1 cubic feet. The IDq 10's use up 0.05 cubes each so with two in there, it'll be 3.0 cubic feet on the nose.
Port Tuning: 27.6Hz with subs mounted, will be 28 exactly.
Anyways, here's a few pictures with it rendered in Sketchup including routered ends and port exit.
First picture is the base board with the sketch of the walls + port.
Next picture is with the walls and port constructed.
Next is a picture with the box completed and carpeting + wood texture added.
Finally is a picture of the completed box with translucent walls and some dimensions to get an idea for the cutsheet and construction of the box.
Hope this is kind of what you were looking for JDBoogie. Suggestions/constructive criticism welcome from both JDBoogie and the rest of the community.
Good luck with those IDq's. Those will sound nice //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Nice!!! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
That's a nice enclosure. Im gonna see if one of my buddies can build it for me!
Thanks Bro i appreciate it!!
DNick454
DNick454
Valparaiso, IN
DNick454
