small motor not to bad a fix. take the basket off. go buy some long 6mm screws and put them in the top plate to seperate the top plate from the magnets. clean up both sides and ruff up with 50-80 sandpaper. put down long setting epoxy on the magnets. cut some hardwood shims so the will stick out of the motor a few inches. with the long (3") 6mm screws put the top plate over the harwoodshims. now back ur screws outs uniform so the top plate comes down even. retap the screw holes because they will have gotten a little epoxy in the threads after it dries over night.
Thanks for the info SPL. I got the motor off tonight. Just so happened to have a bunch of those bolts lying around. Is there any special kind of epoxy that I should use?
