gtristan18
Hello,
As you can read from the titles, here is what I am currently running:
That's about all I am currently running, as well as a after market Pioneer head unit. But anyways, I realize the BOSS Audio 1200 watt amp I have is no really 1200 watts. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif Considering it only takes 2 25A fuses.
The amp really ***** too as well because it's lack of power I guess you could say. I usually only run my music at 30-35 (35 being like maxed out because the amp will go into protection mode)
I have to run the amp with the Bass Boost knob at 0db, the Low Pass Freq, HZ knob at 35 (lowest setting), and the input level a tad bit past half.
As far as the speaker setup goes, I have the 2 subs bridged.
I was wondering if there is anyway I could maybe boost this and not have it hit protection mode on certain bass lines, etc.
Thanks.
- BOSS Audio R6002 Riot 1200-watts Full Range Class A/B 2 Channel 2-8 Ohm Stable Amplifier
- [2] 12 inch 800 watt max - 4 ohms Pioneer Subs.
- Ported Box
- 1200 watt WalMart wiring kit.
Thanks.
