Boomin_tahoe's s10 build
Back on track...due to some rain we got and started working o/t, again...
Bracket which held the jack is finally cut away....took a little longer but that Dremmel sure comes in handy..
Finally got the amp rack assembled. Hopefully I can sand it down flush and corner rounded tomorrow....letting the glue dry overnight...
Doing some test fitting....trimmed a little where needed. Also have a slight hump where the center console back is on the bottom, which explains the cutout on the amp rack...
A little visual....sure does fill up the ext cab area quite a lot!! Hopefully I can get this wired up real soon.
Looks good !
Bro you don’t even meter shlt either... come on beat my score.. I’m waiting you fvcking joke
Im beat the **** with 2 18s when they come in. You didn't even design or build the Box whoever did simply got lucky because you nor he don't know the science behind it if I Wallace 15 up I promise you I'll be doing low to mid-fifties
So your trying to start a subwoofer company but yet you order some 18s for another company //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif such a FAIL. And low to mid 50s ain’t shlt, beat my 158.6db sealed on dash or music. It should be no problem for you with how smart you are
Too bad there isn't a feature on this site that wouldn't allow certain people on build logs...you know, that only the thread starter can have control over.
Too bad we don't have active mods to ban pieces of s hit that troll outside of the dome.
Since it came with a small stereo, I noticed the front right speaker in the door sounded like crap. I'd have to look into that later, as it was rainy season and wintertime. The awesome Panasonic HU was replaced with the Alpine 9833 I had laying around in my garage....
Sounded better but I think the speakers were in bad shape in the doors, and in dash.
When I was installing professionally I always hated having to put HU's in these trucks....that whole fvckin dash coming off...ugh...hated it...I wished they all could been Ford F-1EASY. Cursed S-10 Blazer's and running wires!
Now that I got that out...I always liked the style of that S-10 truck/SUV. They really ushered in the 'not so boxy' look with trucks. I remember my buddies dad got one of the 2-door Blazer's when they were first released...it was dope. Then the Xtreme models...ahh flashbacks to the 90's.
Your HU install looks good...it's nice you didn't use the kit that makes the HU stick out...the flush kit looks much cleaner.
Thanks. And I had owned a 92 s10 blazer....so that install kit which makes the HU stick out another inch or so I hated it...I still have pics of it. But it was because there was no room behind where the HU would go in. No "slim" HU on the market that I know of lol. Yeah I understand the whole dash removal, in fact, I just lifted it up just enough to work around it. My Tahoe is the same way, well sort of. It has snap in pieces so just pull on it, remove about 4 wire harnesses, and that's it. s10 dash isn't bad once I do it enough times....less than 5 mins to remove 5 screws, a wire harness, done. 2 screws holding the HU.
Port pieces together...
Doing some testing/listening....this lil guy pounds pretty good. Look at the sawdust that came out the port!!
VERY nice work on the enclosure! looks very precise. I've been aching to build a t-line enclosure. That 8 looks like a beast!
You may need to go to some shows and sound offs/meetings
I would add two more of the same subs and look at selling the 2k to go towards the funds of a decent 5-8k mono amplifier and new enclosure
that was a pain... 2.5 days probably removing everything, cleaning entire area and doing it. ive only done trunk cars before this was def a lot...
14
Boomin_tahoe
Hurtin' feelings errrday.
Boomin_tahoe
WA
aburger003
    May 22, 2024
    May 22, 2024
