Bondo is drying on door pods, what next?
I just sanded with 40 grit and then just added another coat of bondo to fill the holes. Do I go over with 40 again and then work my way up? If there is more holes/highs/lows do I bondo the whole thing again or should I just bondo where the high/lows are?
sand it more, with a couple more variations in the grits to get highs/lows a little more even. then if there are still pin holes, thin out the bondo, whether with less hardener or add a little resin to it. if you have kitty hair, you can use that on the pinholes as well.
HardHitter
HardHitter
Los Gatos, CA
blue93corsica
michigan born
    May 14, 2026
michigan born
    May 14, 2026
