blowing sub?
Play subsonic tones...crank the gains and the head unit volume to max.
Fastest would just be to hook it up to a wall socket //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so like take an extension cored and plug the prong part in and cut the insert part off then wire it like that
will it just bounce on its own or do i need to play music with it
It's going to play a 60hz tone. You do understand that the signal coming from your amp is an AC voltage that plays different frequencies right?
Yep wall socket. If you plan to recone it, you may not want to wall socket it though. I made the mistake of doing that and had a hell of a time getting all the wire out of the gap //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Leave it plugged in to your setup, turn gains / bass boost all the way up. Turn all EQ settings on your HU to full.
Volume to full.
What sub you trying to destroy? I'd sell it before blowing it up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
snick
snick
michigan
snick
michigan born
    May 14, 2026
michigan born
    May 14, 2026
