15l7's In A X-cab Truck
dflw_99
Kicker Ownage
I Want To Put 2 15l7 In The Back Of My Truck In The X-cab Part And Make The Subs Hit Toward The Front-seats. My Box Will Of Course Be Sealed, I Have 48in Long,16 Deep,and I Would Like To Stay Under 22in In Height.
I Have Got A Calulator And Got These Measures 20in Height,36in Long,16in Deep, Which Gives My About 5.356 Cubic Feet Of Area
My Only Worry Is While The 15l7 Depth Wise Be To Big
And Would 5.356cubic Feet Be Enough Room For Them
Keep In Mind This Is A Truck And Space Is Very Limited
You driving an s10 or a ranger?
For 2 15" L7's I'd imagine he'd need in the neighborhood of 7-8cubic feet and he obviously has nowhere near that. Still, 2 15"s right behind you can hit low and loud...
How Tall Is A 15l7?? Cause I Only Have About 16inch Deep, If It Is Anymore Then The Sub Will Hit The Back Of My Seat
Ill Want To Fire My Subs Like Suproman Did Toward The Rear Seat
i would also like to know is the kicker zx 1000.1 monoblock amp be what i need??
since this amp is stable at 2ohms i would need the dual 2 ohm 157's right?
i was thinking last night, if i decided to mount the subs facing the ceiling would i lose any db's rather then having them hitting toward the backseat. iam not competing, just want it to be loud to the ear.
about the amp, to wire 2 subs using a mono amp all you would have to do is wire 2 wires on the + terminal and 2 wires on the - termianl and use one of each to count each sub right?
i like that idea when someone said runnin two amps would be better
how would you run the power to the second amp??
pic would be nice
thx all who helped so far!!!!
dflw_99
Kicker Ownage
dflw_99
OPP,AL
dflw_99
