Blew a fuse..i want to know why
bmoney9
So last night was coming home from a friends house. Playing the music normal, I didn't think I had it up too high. Anyways, playing a song, next thing I know substage is completely off. I get out the car check all the wiring, its all the way I left it. So I drove home and inspected and figured out I blew a 30 amp fuse on the ground distribution block. I thought if anything I would have blown a fuse on the power distribution block. Did I blow the fuse on the ground side because its a small fuse and it should just be grounded with no fuse?
The reason it has a fuse is because the knukoncept distribution blocks have fuses. Normally I wouldn't have any fuses for ground. That is why I am a little bit confused.
knu makes a gnd block w/o fuses //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
i know this, because i have one... and its on their website.
edit: how big is the fuse on the power side?
i never really heard of any one using a fues for your grounds. i would think where pulling to much amps and u need to bump up your fuse size. i had a 100fuse under my hood in the past and i would blow it cuz i was pulling to much. a simple fix was to upgrade the fuse size.
ive never used a distro on my grounds //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif but thats just me. you dont need the fuse on the ground as long as you have one on the power. id either match the fuse or go bigger on the ground.
me either. my rear battery serves as a distro point. and get rid of the fuses on the gnd side. sell that shit and get a ground block
300 amp, im just goin to take out my fuse block and replace it with a nonfused distro..lol problem solved
bmoney9
bmoney9
Bay Area
bmoney9
