Birch Wood questions
jrouter76
jrouter76
I never used Birch to build a box,I did a little research on the Lowes website review section and there were some not so great reviews about the quality build...sooo my question is where do you guys who use Birch purchase your wood? and what size in thickness do you use generally? lot of questions but how else can I learn?..Box will be housing 2-12 Soundown 12"Zs with an 6"Aero Port. Thanks for input.
birch machines really nice its virtually void free dont use roofing plywood birch is like cabinet grade stuff very high quality
and besides weight and strength over MDF by leaps and bounds it :
1)takes screws .....over and over without stripping
2)makes less dust
3)isnt so damaging to your tools( bits and blades)
4)takes nails and screws to assemble without splitting like mdf
5)dont swell if it gets wet
6)can be stained and the end grain dont **** paint like mdf requiring tons of work to either seal it or coat it until it stops absorbing
So does that include taking roundovers to it? I wanna go as big as possible considering the small size of my trunk and squeezing that thing in my trunk hole will be helped with the use of roundovers. Not only that, but it just looks much nicer. I also like the idea of having much less weight in the back.
use wood glue. Pl400 and the similar are construction adhesives mostly used for gluing plywood down to form floors. It's not made to bond the 2 pieces together to hold when constant pressure is applied.
jrouter76
jrouter76
jrouter76
Mount Vernon ,Illinois
wenn_du_weinst
