biggest 1ohm amp that puts no more than 1000-4000 at 4ohm
^^^ same board as hifonics sampson and other 8-9k amps. not near 20k i hope u know
I own both, AQ20 and Hifonics Sampson, boards are "similar" but the AQ makes more power on a 12 volt system..and is a lot more stable for daily use..AQ20 does on 12 volts what sampson does on 17 volts..they can be modded to run up to 18 volts, and with enough batteries and a reactive 1 ohm load, I bet it will come close to doing 20k...clamped a little over 10k with rise to 2.8 ohm with my 20k...
haha thats basic talk some people will start throwing around #s that i have no idea what they mean and do calculations that i dont understand
lol, well I actually understood all the numbers I was just very surprised that amp manufactures are making "off the shelf" amps that put out over 12,000 RMS! I remember when the SoundStream Colossus was THE bad boy... There were a few others but that's the one that stands out in my memory.
stetsom has a 14k I believe if not more..
10 SAZ 1500d would be exactly 4000w at 4 ohms:thumbcool:
25,000 watts with 5 pairs strapped at 1 ohms @ 14volts:bowdown:
STUPID watts with 5 pairs strapped at 14volts:goldcup:
Plus it would look absolutely crazy with 10 of them!
on a 12volt setup?
might wanna retest that //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
9515ROB
TEAM DTF
9515ROB
Sherman IL
soundstreamer
AJ (ACE)
    Jun 24, 2026
AJ (ACE)
    Jun 24, 2026
