Big-time customer/ Big time problem
Try grounding the RCA's. Some Pioneers seem to have an issue with their RCA grounds.
Make sure all amp ground are sufficient. Sounds like a grounding issue to me.
thinking the radio is suspect also...where is the unit grounded? sure the rca's are fully connected? did you tape them together?
The head unit is grounded through the wiring harness.. The rcas are fully connected and no they are not taped together.. Its hard because we dont do the guys installs
---------- Post added at 03:46 PM ---------- Previous post was at 03:46 PM ----------
Its just wierd because if it was the head unit then how come it doesnt have a problem with the key turned back
It sounds like an amp grounding issue. Whining noise points to that immediately, and it may be shutting off when you turn it up because it's not getting the juice it needs.
well its a grounding problem for sure, why not start with the easiest ones which are the amps.. Its very basic but sand off the paint on the chassis and ground the amps to the chassis. What is the reasoning behind grounding the amps to the battery instead of the chassis?
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
MerkConvoy501
MerkConvoy501
Conway AR
MerkConvoy501
    May 31, 2024
    May 24, 2024
