SicAudio
did you fart dude?
strand count is for flexibility, call any wire supplier they will tell you the same thing.First: 2/0 weld wire comes in alot higher strand count than 12.
Second: I have a system.
Third: my dad is an electrical engineer w/ an MBA & 25 years in the field..... I'll take his knowledge over yours any day. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Fourth: using car audio wire over welding cable might have something to do with sponsorship. Why spend thousands of dollars on welding cable when you can get sponsored. Also.... car audio cables are not true AWG wire, they are oversized...thus 1/0 car audio is bigger than 1/0 weld wire (which is true AWG), & that means a higher current capacity. It has absolutely nothing to do with strand count. All that does is makes the wire more flexible. Again.......
Strand count has nothing to do with DC current flow. It's all about the cross sectional area of copper.
this here is exactly what I have learned...
Your argument was that car audio wire has a higher current capacity than weld wire because of a higher strand count. And guess what: you are wrong, again.
I remember a similar thread from last year so I contacted a distant relative that owns 1 of the most prestigious wire companies around and he said the same thing...
thread count is for flexibility.. AWG ratings are a standard regardless of 1 strand or 2000 strands..same amount of current either way..
