Best Way to Stop Sunroof Flex?
  • 6
Hey guys,
I drive a '97 Acura Integra. Let's just say the lows make the sunroof go nuts. What's the best way to reduce the flex/noise without removing the actual sunroof and mechanism?
You may want to try and fill in the cracks around the side of it with expandafoam...Ive seen the spl guys do that with the CRX Si's then a couple of layers of deadner over it...
Your best bet would be to remove the trim and headliner and try to find what's actually making the noise. There might be a cable, actuator mechanism, locking latch or something that could be isolated, tightened, or shimmed. I'm assuming it's a factory sunroof and most likely has seep drains. Be careful not to cover those or the channels that run to them with any tape or foam or you'll get wet seats every time it rains.
A $200 budget is do-able but a little tight for certain features wanted verses needed, and will take a search to find what you want. Id deff look...
64
633
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
ObTechAudio
ObTechAudio
Provo, UT
Snapper_Slapper
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
