Best Shallow Mount Subs Available.
Which Shallow Sub Would You Buy Again
  • Alpine SWR-T12
    Votes: 7 33.3%
  • Kenwood eXcelon KFC-XW1200F
    Votes: 3 14.3%
  • Kicker CVT122
    Votes: 2 9.5%
  • MB Quart RLP 304
    Votes: 3 14.3%
  • MTX Audio TT6512-02
    Votes: 0 0.0%
  • Pioneer TS-SW3001S2
    Votes: 3 14.3%
  • Rockford Fosgate Punch P3SD212
    Votes: 3 14.3%
  • Total voters
    21
I haven't purchased any amps yet so power will be decided once I figure out the requirement and as far as air space I'm thinking I can get up to about ~.75 cubic feet per sub. Because of the limited space I was thinking of building a sealed enclosure. If I go with something like the SA-8 I could go sealed or ported since they take a relatively small enclosure even ported.
I have heard the JL slim and the Memphis slim and both sounded good. I was told that both were in larger than spec ported boxes, so that may play into your install. The BM 2 is supposed to be incredile if you can find one and I heard that is more the issue so I would rule it out. to be honest unless mounting depth is really the issue, I would run mulitple small subs before going with a slim. 4 or 6 6.5" subs like the new DD's woud be the route I would go
Based on what others have said from the Tacoma forums I should be able to get around 5.5" - 6" mounting depth without modifying my back seat any...which I'd like to stay away from. Also, I don't really mind having something that alot of others have I just want it to sound good. I'm definately feeling the smaller subs over the slims, but like the idea of an 8" over more of a midwoofer option.
Dj-torn
Still learning...
Dj-torn
Fairchild, WA
gsxr1300
