Using WinISD is great for calculating port length and diameter given a fixed enclosure volume and tuning, but for actual in-car response it's pretty worthless. WinISD generates a theoretical response curve if you were listening to the speaker system in an anechoic chamber. Your living room, listening room, and bedroom all have cabin gain at some point (room cabin gain typically starts in the 20's). Vehicles have LOTS of cabin gain and all of them start high in the 45 to 50 Hz region. In a vehicle, hitting your target F3 (it should be in/around the mid 40's) is the most important aspect. Qtc is valid for home applications, but not so much for cars due to the +12 dB/octave gain you get starting at approximately 45 Hz. The overall response curve and more importantly bandwidth are what you are after. The broader the bandwidth, the better the transient response, and the happier you will be unless you're after a one note wonder.
When you are comparing the RLP 304 to the Alpine keep in mind that the Alpine has a more linear response because its Qtc is significantly lower. Qtc relies on Qts, Fs, and Vas, all of which the Alpine type R shallow has the advantage of. The Alpine shallow Type R has a similar rise in response as the BM mkIII (~2 dB) in the 60 to 80 Hz range in 0.5 ft^3 sealed. The RLP has a 5 dB rise, again due to the bad alignment in 0.5 ft^3. Which, by the way, smaller sealed enclosures don't make the bass faster or tighter! Their "tight bass" label for their smaller enclosure recommendation is completely erroneous.
All this while you have been comparing a single MB Quart to a single Type R shallow. And there has also been discussion of 0.6 dB louder, quieter, etc. 0.6 dB is not detectable by the human ear. 3 dB is a noticeable difference in loudness. 1.5 dB is incredibly hard to notice, let alone 0.6 dB. The latter means that you will not be able to hear a 0.6 dB difference. And as I previously stated you will need two of the other drivers besides the Type R shallow to equal the output of a single Type R shallow. Double the volume will be required, more money spent on enclosure materials, and you will still end up with less low frequency extension compared to the Type R shallow. Not to mention that the Type R shallow is the baddest shallow subwoofer available for purchase right now. A 4" voice coil, channeled top plate, hollowed out spider to move through the top plate, and big neo magnet slug all add up to icanbeatthepissoutofthecurrentcompetition.
