Best pair of 12s for price range...
How does a dual battery setup work, anyway? Does the alternator charge both? What does the 2nd battery do? It'd be awesome if you could explain it to me.
Yes it does, run your pos from the first batt to the rear, ground the rear batt like you would an amp. Then wire your amp off the rear batt. And you can ground your amp to the rear batt as well
Now, that keeps both batteries charging? You'd need a HO alternator, right?
That is correct. Also really helps to do your big 3 and use 1/0 to the back. Although not required.
Yeah, I've got 4ga Knu that's gonna go under the hood at some point. I might even up that to 1/0 gauge, and then run it to the back if I up the power that much.
I'd up it to 0 if I were you man.
Dat bank account tho. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I really can't do much until work season starts back up.
Lol it's not a necessity, just as time permits
Yup. Again, I won't have money to blow until probably summer time, so that's when I'll really splurge on subs, wiring, batts, etc. I can't friggin' wait.
On a sealed sub box if I faced the subs up, I lost quite a bit of bass. Faced them forward, they worked great. On a ported box with subs and...
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
840
655
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
546
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
690
Full Tilt
Bonafide MAFer
Full Tilt
Iowa
04murdalanche
