i guess i will, i forgot those!!!then TRY the AA polys. If you don't like 'em, sell them. Mine will be here tomorrow.
Which polk components do you have?
i went ahead and picked up the arbiter TM set. the TWEETS can 450 for long periods of time, I wouldn't push an IB setup that hard. Maybe in a proper enclosure I'd go over 100rms.i guess i will, i forgot those!!! half of my system will be AA:naughty: loll
oh and i forgot, how much power yall givin' ur Poly mids?
i got 200rms each doors now with polk(gains little over half), yall think the poly could handle it?
sure, I got TM-1 since I am going active.did you get the TM1 or TM2? the tm2 has the crossover, just wanted to see if you would be driving them active or passive.
post up a review once they are in and you listen to them, I was considering getting a pair to demo against my SEAS stuff. //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
That depends whether you consider TIME=MONEY.anyone know a pretty dammn good woofer for the buck that could play from 80hz to 2.6khz nice and loud, espacially mid-bass, (80hz-250hz)(6.5inch or 7inch)
thx
Definitely second that thought. That's always been my experience, too. Can't fight basic physics!. If you are just going to drop it into your door, do yourself a favor a get yourself a higher Qts driver-preferably a high +0.5x-0.6 to not be disappointed.
I havn't gotten the bodeis, or payed for my DQT yet, so I am unsure on what these retardedly bad boys are capable of, I keep talking about going to 800 and trying them out and mr. jizzle keeps telling me I'm insane, so without someone local for me to talk to about running them (as I don't want to bug the shit out of you guys on here), I'll be waiting till I have them in and fairly well tuned with an RTA to start seeing where I can take them. I like finding stuff out on my own a lot too anyway... if I go slowly and listen for the driver stressing, then I KNOW what it sounds like instead of just going gung-ho and having to get new diaphrams after 2 days.1.5k? Pssh....wussy //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif I haven't looked at the specs of that particular driver you'll be using (and too lazy to right now), but full bodied horns are good down to ~650hz IIRC. If the compression driver will sustain it, and you're using a 24db/oct slope, I'd try no higher than 1khz as a highpass point for the horn.
But to answer your question about the 8"...yes, you'll be fine, especially if you push that xover point down a little more. Beaming for an 8" doesn't begin to be horrible until about 2khz as Gordon mentioned. At 1khz, an 8" woofer should only be about -3db down at 90* off-axis. At 1600hz, an 8" would be about -3db down at 45* off-axis.
Moral of the story...you should be fine if you keep it more than 45* on-axis, especially if you drop the xover point like you should.
