negative, dayton reference 7" 4 ohm version 32.70 per.....http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=295-374AA Poly mids....35 a pop cant be beat...
I don't think you'd want to run those up to 2.6khznegative, dayton reference 7" 4 ohm version 32.70 per.....http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=295-374
yea true but if cross at 2khz at whatever slope, it'll still play 2.6khz //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.I don't think you'd want to run those up to 2.6khz
anyone know a pretty dammn good woofer for the buck that could play from 80hz to 2.6khz nice and loud, espacially mid-bass, (80hz-250hz)(6.5inch or 7inch)
thx
Well thank you for that course in crossovers 101 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifyea true but if cross at 2khz at whatever slope, it'll still play 2.6khz //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
according to his original post, my post is still valid //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.Well thank you for that course in crossovers 101 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I was simply stating that, per the original post, it sounded like he was looking for a driver to be crossed at 2.6khz. Which would exclude the Daytons //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Underlap worked for you....doesn't mean they'll work in every situation //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifaccording to his original post, my post is still valid //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
Definatly have heard good things about Dayton. You may want the check out madisound.com ... mostly 8ohm drivers, but some good choices. What's ur budget? Don't you drive a 4th gen?? If so look for 8's //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ya '96 i think its a 4th genDefinatly have heard good things about Dayton. You may want the check out madisound.com ... mostly 8ohm drivers, but some good choices. What's ur budget? Don't you drive a 4th gen?? If so look for 8's //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
