Best low budget amp with clean power
i haven't bought the sub yet so ohm load can be 1, 2 or 4. Someone told me the audiopipes put out dirty power. Is that true or are they just trying to sell me on their amp?
yea the audiopipes arent the best ..u better snag that aq1200 on ebay before someone else does...its solid clean 1200+ rms @1ohm
If you can get that audioque used for $30 more than the audiopipe new defiantly go with the aq1200
plus you will probably get at least 400 more watts than the ap1000
If you can get that audioque used for $30 more than the audiopipe new defiantly go with the aq1200 plus you will probably get at least 400 more watts than the ap1000
Also less voltage required and cleaner..
I have done a lot of research, but as always, there are too many choices and they all seem to get the same review. I'm looking for a deck that...
625
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
sjuddslvrss
sjuddslvrss
Rochester MN
mylows10
pfft
    May 1, 2024
pfft
    May 1, 2024
