Best Bang/Buck Sub for a Hifonics ZX7500 Amp?
I have a New Model Type-R 12 for sale, dual 4 ohm, run your amp at 2 ohms and it will push 1000 easily //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif But it might get a little hot. I would sell it for 90 plus shipping. Its in decent shape with barley any scuffs on the rubber surround.
1) His amp doesn't run mono at 2 ohms.
2) At 4 ohms, he would only be able to give it about 400wrms.
3)
//content.invisioncic.com/y282845/emoticons/wallbash.gif.1310150c49dd52e0fbe1813a0681e5c3.gif
But... back on topic.
Might wanna look at a new SE or SX from the RE group buy.
So then what does that leave me with, a type R? Since the amp wouldn't be able to push out the 800RMS the LI should be fed... but aren't the LI subs pretty efficient?
And what EXACTLY does 1 X 1000 Watts @ 4ohms bridged mean?
Doesn't that mean if I get a 4ohm sub looking for ~900W, this amp can push it?
The amp can do ~800wrms at 4 ohms (rated 1000wrms at 4 ohms). So you would be looking at getting a sub that would put a 4 ohm load on your amp. That gives you a couple options, most commonly:
-single 4 ohm voice coil
-dual 2 ohm voice coils
If you got a dual 4 ohm sub, you'd be putting an 8 ohm load on your amp, which is roughly half of the four ohm bridged rating. You could do this, but you'd be looking for a sub that has a rating of ~400wrms.
Mother F*cking OH!
It all makes sense now.
Wouldn't that L.I. sub be a pretty good choice? Or should I just stick w/ a 12" Alpine Type R? Keep in mind that I already have a ported enclosure that I'm trying to put it in.
BTW Thanks to all teaching me slowly about CA.
Haha, I haven't heard either of those subs you mentioned, but I've heard good things about both. I'm guessing most would choose a LI over the Type R. Anything made by IA is built like a rock.
Might wanna check out RE Audio. They have a group buy going on here.
Yeah, I've read all about RE, and I like what I see over at realmofexcursion, but it's a little too rich for my blood for the time being.
Yes, but that SE's oem configuration is dual 4ohm, which would cause my amp to only be powering it w/ ~400W right? Am I actually learning? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
PRoJeKV6
I Need A Freakin' Pic
PRoJeKV6
ŅeШ YoЯK ©!
PRIVATEpastry
