Hello everyone, I finally got the $600 or so dollars to buy my system for my 201 Blazer and I think I know what I want now but I just want to make sure with you guys that I got the right stuff here that will work together to give me the max wattage out of what I am getting. Here is what I am planning on buying all from crutchfield.com.
Head Unit: Alpine CDE-9842 CD player with built-in amplifier (16 watts RMS/45 peak x 4 channels) $89.99
Subwoofers: Pioneer TS-W301R 12" 4-ohm subwoofer power range: 50-150 RMS watts (800 watts peak power) $99.98 for 2
Amplifier: Profile HA1000 2-channel car amplifier 160 watts RMS x 2 $109.99
Front Door Speakers: Pioneer TS-G1641R 6-1/2" 2-way car speakers power range: 2-30 watts RMS (160 watts peak power) $49.99
Dash Speakers: Pioneer TS-G4641R 4"x6" 2-way car speakers power range: 2-20 watts RMS (100 watts peak power) $49.99
Mid Panel Speakers: Polk db690 6"x9" 3-way car speakers recommended power range: 10-100 watts RMS $99.99
Subwoofer box: Will build myself, dual sealed enclosure,
Amp Wiring Kit: Rockford Fosgate RFK10i 10-gauge amplifier power and signal wiring kit $29.99
Speaker bracket and harnesses: free from crutchfield
Chevy s-10 Jimmy kit for head unit: $12.99
GM wire harness reciever: $9.99
GM Antenna adapter: $9.99
I do have a couple questions also if anyone could help me.
1. Is this all the wiring and adapters I will need to install it myself or am I missing something?
2. Is this a good setup, meaning, will the amp push the subs to their full potential without overloading?
3. Do I need an amp for my dash,front,and mid speakers or not? and also should i buy bass blockers for the front, dash, and mid?
4. While on crutchfield they said I have 4x6's in my dash but then while checking out it says they will not fit in my truck, so I went back to look at others and it says none of them will fit, so is this an error on their part or will none of their 4x6's fit in my Blazer.
5. Lastly, Will I be able to set up all 6 speakers to my head unit even though it is only four channel?
Thanks in advance for anyone that answers any of my questions, I don't expect everyone to answer every question I have but any input would be appreciated. Thanks!
