Battery/Wiring Question
ingine53
I have a side post battery(Autolite 84) and have decided to buy new terminals for it since my other ones are stripped. I found one online and was wondering if it would fit on my Autolite 84 battery. Here is the link for the terminal.
http://www.goldstaraudio.com/installation/battery-terminals/stinger-spt55309.html
Also, I found some ring terminals for my 1/0 AWG wire I bought and was
wondering if it mattered which one I got. Below is the link to both.
http://cgi.ebay.com/2-Wire-Ring-Terminals-Gold-1-0-Gauge-3-8-Connectors_W0QQitemZ190360753827QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2c526296a3#ht_2190wt_1167
http://cgi.ebay.com/2-Wire-Ring-Terminals-Gold-1-0-Gauge-1-4-Connectors_W0QQitemZ190360753865QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2c526296c9#ht_2190wt_1167
My main question was if I buy that battery terminal, will it fit on my battery. I tried to look up my battery and couldnt find any information. The info for the battery terminal says "Perfect Fit for GM Side Post Batteries" so I'm assuming it would fit right?
You will have to look at your vehicle too, some GM's have 2 positive connectors at the battery (like my old Cadillac Eldorado) and you will need to find the "long" version of those side post adapters, if you only have 1 positive connector those will work fine.
EDIT: just saw you linked the "extended" one, make sure that you need them or they will be too long
ingine53
ingine53
Tucson, AZ
Joebobclark
