Wiring LOC with stock bose system
I just recieved the soundgate LOCX line output converter. I have already found my subwoofer wire coming from the bose amp. Now, the LOC has 4 wires for both left and right rear speakers. Since I am wiring them up to my existing stock sub, can I bridge both wires. like twist both positive together and t into positive sub wire, and twist both negative together and t into negative sub wire? There is a switch on the board to change leads from full range to lo pass. I have already changed both leads to lo pass for the sub hook up. The LOCX has a 2ft twisted rca into the ISO2v2 which cleans the signal up, and then those rcas go into my rainbow mono amp.
If you twist the negative from one to the positive on the other and repeat for both, that will improve sound quality. You will find this to be much better.
you only need 1 set of wires. good luck making that work on a bose system. the Merc i tried didn't work //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I cut apart an old rca cable I have and spliced the wire into the rear sub wire to see if I would get anything. I got some good bass, but it was pretty low. Im hoping this LOC will work. How did you work on the Merc?
you realize you just told him to cross the positive and negatives right?
idk if the dude is joking or what.
Do not do that. wire the positives together and the negatives together and then tap in.
yep.
there are some d-bags on the forum, no worries //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
racinstylez
racinstylez
Houston, Texas
x1le
vegang
vegang
