Battery Terminals
There was a separate bolt and nut on the OE terminal connected to my positive post, so I stacked ring terminals on there. There's only two rings and the system is under 1kW RMS and the two runs are 4ga, but I've never had a problem.
I think it's more of a convenience thing; I can definitely see the need if you're running multiple 0ga runs simply because there'd be no room to fit all that in a tight space.
yeah, im running multiple 0 gauge big 3 and 0 gauge for power,
all I can find are these basic ones
0113501_1
So I will have to put at least 2 side by side,
0113501_1
Im in the same boat as you as I am about to do the big 3 and need to run multiple runs from batt to back. I cant find terminals with multi holes for 0 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i found some at princess auto but its only 4 and 8 gauges, and I dont want to order online, but if its safe to stack side by side i will probably just do that
bigd26
bigd26
Toronto
danny1mmafan
