battery terminal broke off
thegreatestpenn
lazy genius
Can I put it back on somehow? maybe weld it back on? any type of glue that could help? here's pix:
so like, no one realized how much current is going to flow through that little tab...and how glue is totally not conductive? Plus those terminals are usualy way to soft to weld but you could try. Cant fuck it up much worse.
if theres any type of glue that would work ( which i doubt) it would be gorilla glue
i'm sure yu could tack weld that thing back on in seconds though, that would be my first attempt
doesn't seem like it would be the greatest idea to get a hot flame from a welding torch anywhere near a battery. //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
i talked to Mr penn. try and fix it, if you cant ill ship out another battery for you ASAP. make sure you do a semi professional job. drill a small hole and tap it with a tap then run a larger size bolt try and get a tap with lil bit of tread that are bigg. the terms are lead so i donno bout welding it .
Lead = very soft
Its pointless to try tapping it out and putting a bolt into it //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
thegreatestpenn
lazy genius
thegreatestpenn
columbus
hoxie08
