are u sure you even know what a cap does? a cap stores power then releases when the amp needs it. it doesn't just flow through like leaving a light on does.Then what is powering the cap when the engine is off?
Not sure how tha Dblock works.Just checked the battery, after 4 hrs it has dropped from 11.8 to 11.4.
This may sound stupid... but what tells the cap and d/block to turn off when i turn the car off? does it need a remote wire like amps do?
That would depend on the ESR of your cap and the AH rating of your battery, combined with any other additional loads present.A cap is nothing more than a storage device. If it is indeed faulty and "leaking power some where then it is possible to drain the battery. I for one have a 35f cap in my car and after being on vacation for more than two week this month my car stated perfectly.....if caps drained the battery, dont you think over a 2 week+ period in 30-40 degree weatehr I would have been in trouble?
Yes I am sure how a cap works and does not work. If you think a cap is helping him in any way other than being a fancy DMM, then you have no idea how they really work. If you have not already, read the studies of Richard Clark. The guy selling you caps at your local store surely has not read it. Caps have a relatively high ESR which leads to them needing to be contantly recharged. It is exactly like having a light on, just a very small one.are u sure you even know what a cap does? a cap stores power then releases when the amp needs it. it doesn't just flow through like leaving a light on does.
Yes they should quit buying caps and toss out the ones they have now. The only people who bennefit from the purchase of a cap is the people making money in the transaction. The caps onboard an amp are not constantly powered. They are only powered when the amp is turned on. Therefore, they do not pull power constantly.I think everyone should throw all caps they have in their car cause they serve no purpose.
If caps all **** what about the ones on the amp board? Do caps really do nothing? //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Nothing turns off those devices. The cap will continue to try to power itself endlessly. While it leaks voltage due to it's high ESR and heat output, it is draining your battery. While it sounds like you have either a rather defective cap or some other device that is draining your battery that quickly, the cap is really not serving you any good at all to begin with. It should be removed nonetheless.Just checked the battery, after 4 hrs it has dropped from 11.8 to 11.4.
