bad battery???
  • 5
ta2ed9783
I putchased a Kinetik kr3112 agm battery from a guy on the classifieds section and I just took it to get it load tested cause it only rest at 12.6 or thereabouts. Autozone tested it at 800cca's and just said it was 100% charged but a bad battery. Advance gave me a printout, he tested it as. 2000 amps batt since that is how it is advertised.
Results ;
Voltage: 12.68
Measured: 483 CCA
Rated: 2000 CCA
Temperature: 65° F
Is there any way to save it or is this normal cca's for this batt?
You could try charging it but a battery will read 12 plus volts. How big is the battery? Does it say it has 2000cca? Im pretty sure it does not.
I can't find any real specs on it besides 125 ah's. It's 63 pounds. Basically like the Kinetic hc2400 only its red.
But im thinkin they use a load tester made specifically for standard batteries.
---------- Post added at 11:28 PM ---------- Previous post was at 11:28 PM ----------
I have seen a few others post about their agm batt testing as "bad" on a autozone load tester
Sounds like a bad cell inside. Some batteries are just bad from the factory. I have had it happen to me before. Dude at battery warehouse swore it was my alt till he tested that lol. He replaced it with a new ones and no problems.
any time I get an agm batt that seems to be acting up I hook it up to my smart charger on a 2a trickle. It will tell me by the morning if I have a bad batt or not. It will actually display BAD.
That's why I said it really depends on the sub 😂
16
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
ta2ed9783
ta2ed9783
enterprise, al
ta2ed9783
