Back battery wiring question
Bobby322
Do I have to have a ground run from my front battery to my back battery? Or can I just ground the back battery to the same spot I ground my amp to? Last time I tried to, I just grounded the back battery to the same place my amp was, and it smoked. I didnt know what the problem was, but I forgot to reconnect to front battery ground. once I did that it didnt smoke. Maybe it was because I had already partially blown the amp? I just got a new amp and I just want to make one power run from the front battery to the back battery and ground the back batteyr sperately. I really dont want to smoke this amp
you ground it to the same place as your amp. well it doesn't have to be but it can.
but you don't run your ground from your front to the same as your back batt.
these are separate
i'll sell you my 1g for cheap.
but if you don't mind waiting.
i picked up 55 ft of welding cable on ebay and it's supposed to come in next week, after i use it, i'll sell it to ya.
i'm only using maybe 30 of that 55.
thanks but im about to go buy some localy at a shop for 4.50 a foot. I just wanted to make sure I can hook it up this way and not smoke my amp.
I would run your amp's ground directly to the rear battery's negative and then ground the rear batt's negative to the chassis if youre doing it that way
yes.
*this is what i meant im doing. im doing both of my amps power wire to my rear pos bat, and both of my amps ground to my rear neg bat and just grounding the rear neg batt.
Bobby322
Bobby322
TX
Alpineforever
NorthFramingham
    Jun 30, 2026
