Audison LRx1.1 Fan
Herro
Asia
Ok...I've got this amp with a nice 40cm fan sitting on the PCB. Everything is nice except the fan runs loud giving its size and rotation speed.I got three solution which I can't decide so I'm open to suggestions.
1) Add an external 120cm low rpm fan outside bottom case cover. Turn on together with amp remote.
2) All of option 1 but take out the internal 40cm fan.
3) Take out the internal 40cm fan. Add a 120cm fan outside bottom case cover but route the power on/off source from PCB board. In this case fan will only run when amp is hot but with lower noise.
Note:mounting is not a problem.
Herro
Herro
Asia
keep_hope_alive
