Audiobahn AW151T Sub Wiring Connection? Im Confused!
thanx. that was perfect. anyways i also have a 4 Channel Amp that im running the sub with and there not bridge what so ever. so how would i get the left and right on the 1 sub?
You can only use two of the four channels. You will have 4 terminals per two channels right!
LEFT + LEFT- RIGHT + RIGHT-
So you are goint to use the LEFT+ and the RIGHT- to bridge it. So that is what you run to the sub like I have it drawn. The other two channels arent going to be used unless you have another sub
*NOTE* I have heard of people running all four channels to a dual coil sub. I have never did this so I can recommend it. Ask someone who make have done that type of setup before
Just two of the four channels.
Take two of the channels and use the LEFT+ and the RIGHT-
Depending the layout of your amp it should be something like this
L+L- R+R-
L+L- R+R-
Take the top two channels and like i said put the positive in the L+ and the negative in R-
L+L- R+R-
L+L- R+R-
So out of all 8 terminals on your amp you will only be using two of them
deathroll77
deathroll77
sacramento
Korn4Life
