Audiobahn AW1206Q DVC Wiring Help
  • 2
jlg1783
Okay so here's my question. I just got a new Audiobahn AW1206Q DVC sub and was planning on installing it but then I noticed its input terminals are not like anything I've ever seen before. I realize that obviously DVC subs are supposed to have two seperate speaker inputs (one per coil) but this one has four. On both sides of the subs there are 4 terminals in a row like this O O O O
The first two are labeled positive and the second two are negative. Each coil has these four terminals so how in the hell am i supposed to wire this thing???? I am just going to be running the one sub and powering it will be a
Sony XM-1600GSD. Its a Class D monoblock subwoofer amp which is 1-ohm stable. Until I got confused by the extra terminals on my subs I was going to hook up the two coils in parallel but now Im not sure what to do. Any help would be appreciated since Audiobahn's Tech Support has yet to respond to me.
P.S I am not new to car stereo installation at all. I have done dozens of systems for my friends, but I have never installed a DVC sub before. So if this is the normal configuration for these things I apologize for my idiocy.
FYI.. These are not a Car shaking sub.. But these will give you some pretty nice bass in almost any vehicle that has nothing at all. Best placed...
5
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
81
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
4
Its never justifiable to rush a clean install. Its best to do research for the proper speakers needed and wanted and amplifier to supply for the...
37
6K
jlg1783
jlg1783
Greendale, WI
rmassalene
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
